Hi All,
Bought this to replace my current car but have decided to buy something else. Only traveled 138000 km(original owner bought it in 2008 with 78,000kms and did 54,000kms in it...I have done the rest and unlike most gray imports this is genuine KM's). It won't last long at this price $15,990. The rego is paid for the next 11 months until August 2016. This is a great car....drives and feels like a new car. Its got a brand new clutch, caster arms and lower ball joints, Standard 19" factory Ray's wheels, Impul exhaust, rear bar and side skirts fitter from factory, Stereo is a near new Pioneer and features Bluetooth, reverse camera(not hooked up...but all the parts are there), Digital Radio and can accept a USB hard drive. This car is a series 2 so it gets all the chassis bracing, better brakes, LSD and nicer interior. This car in this colour with a 6 speed and series 2 is a rare care. I believe it is P-Plater approved in some states but please double check.
Car is in NSW.
Please call for more info on 0406754304
cheers
Craig
post-37023-0-85579900-1442874949_thumb.jpgpost-37023-0-09759000-1442874965_thumb.jpgpost-37023-0-85472300-1442874980_thumb.jpgpost-37023-0-05674600-1442874994_thumb.jpgpost-37023-0-15221300-1442875011_thumb.jpgpost-37023-0-22651000-1442875024_thumb.jpg
post-37023-0-50307200-1442875039_thumb.jpgpost-37023-0-15924500-1442875061_thumb.jpgpost-37023-0-17314900-1442875080_thumb.jpg
  • Like 1
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
