Looking for a drivers side hook that's in the boot. It's right beside the tailgate... Its the hook the Cargo/tonneau cover hooks onto to stay shut/up
As circled in the following, but just the drivers side
https://www.sau.com.au/forums/topic/459983-wtb-s1-boot-cargo-cover-hook/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
