CP forged pistons 86.5mm
STD rods
Metal head gasket
ARP head studs
New bottom end bearings
N1 oil pump with remax chrome Molly gear set. Machined bores with decked block
N1 water pump
-5 turbos
Nismo 660 injectors
Nismo fuel reg
Power fc + boost control kit
K and N air filter
Custom lobster back twin turbo pipes and rear turbo inlet
Nismo copper mix twin plate clutch, new
Nulon 15/50 oil
Edfc
Auto watch alarm
Kenwood Double din head unit with hands free Bluetooth
Mint STD interior
Nismo exhaust +custom cannon
Greddy Aluminium radiator
Nismo high flow fuel pump
Tein HR coilovers
Front upper control arm elongated bushes
4 wheel alignment -1.7º all round camber
Rays Engineering progressive rims
New discs, slotted front
Brake pads QFM-A1RM
Yokahama 555s 275/30/19
Nismo oil catch can
Custom over engine barrel style catch can
Custom cold air intake, direct to std airbox
Boost 1.5 bar 370awkw tuned for midrange torque and response not big numbers
Runs pump liberty 100 max fuel
Built motor at 112 986, currently at 120467
Please text or ring for enquiries
Mike 0416085323
post-9995-0-91959900-1443389394_thumb.jpgpost-9995-0-21384300-1443389448_thumb.jpgpost-9995-0-32536500-1443389517_thumb.jpgpost-9995-0-94220700-1443389536_thumb.jpgpost-9995-0-21470600-1443389559_thumb.jpgpost-9995-0-80180900-1443389599_thumb.jpgpost-9995-0-18612100-1443389629_thumb.jpg
  • Like 1
https://www.sau.com.au/forums/topic/460006-fs-r34-gtr-v-spec-55k/
  • 1 month later...
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
