hello guys
here is list of stuff i have for sale
1) used Rb26 apexi D-jetro ecu no hand controller part # PFC GTR33D 020-0923 - 630 USD free ship
2) used RB26 apexi power fc w/hand controller part # PFC RB26 9605-0738 - 630 usd free ship pics to come
3) NEW RB25 apexi Power fc with EL hand controller pfc # 414-AN012 last generation not sure its D-jetro or L jetro but comes with Newst model hand controller - 800 usd free ship
4) Blitz i-D dual asbc spec R boost controller + i-D power metter - 420 usd free ship
5) Blitz dual sbc spec R bost controller -250 free ship
6) HKS hard pipe kit - 350 usd free ship
7) HKS hard pipe kit with two hks blow of valves - 350 usd free ship
8) RB26/25 splitfires set of 7 - 350$ free ship
9) HKS/Greddy 60mm boost temp pressure egt gauges black white have like 20 units 130-190$ per gauge
pictures on request everything is great working condition
let me knowif anyone got any interest
Edited by avoiee
bump
apexi D-jetro - Sold
blitz I-D boost controller - Sold
rest still for sale
Got hks gt2530 twin turbos w/hks actuators - 1600 usd shipped
sard twin suction kit like new condition - 300 usd shipped
the PowerFC is $1,000AUD New. You're asking 800USD Used which is $1,100AUD. Might need to adjust your pricing. If it fits a Rb25DET NEO I'll be willing to buy one if suited to the AU market.
part number is in pictures you can check if its fit , i have no idea if it does to Neo engine , have some room to adjust price
Pm re: suction kit
replyed
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
