  • Replies 69
if you know the answer to a question, why ask it sydkid?
Hoy, I though maybe you knew of an ECU that worked with the auto that I hadn't heard off. That's why I asked, I don't know everything you know. :headspin:
Plus I did say sorry, that I was a bit harsh on you, already. But I will appologise again. I am sorry, I meant nothing more than stopping another urban myth from spreading. :ak47:
Plus I keep hearing about aftermarket ecus'; that "work" with autos. But when I chase them down I keep finding stuff like "it revs out a bit more now before it changes", "the change from first to second isn't as smooth" , "it's a bit more jerky" etc etc. To me that means it doesn't work. So I keep looking for the elusive one that truly does work PROPERLY.
:rofl:
Hi guys thanks for all your input i might get a set of cam gears for now and see what it does then the fuel pump. can some one let me know where i could get some cam gears and how much ruffly i'm in melb
what cam gears are you gonna get, just interested as i am chasing the same kinda out put
at the MO mods i have done
auto r33
cat back 3' exhuast
apexi boost controler in car
hks mushroom
GTR size intercooler with 2.5' stainless steel piping
stage 2 clutch
=187rwkw
in next three weeks
3' dump pipe
high flow cat
GTR fuel pump
uni chip
metal pipe replacing the intake plastic pipe
im hoping for a figure between
200-220rwkw
then prob a cam gear any reccomendation?
go sydney kid, something thats not to wild still an everyday driver
Hey jager i wouldn't have a clue what type of cam gears to get i still want it as a daily driver as well as i just thought all the cam gears were the same also jager did u notice much of a difference when you fitted the uni chip?
Cam gears ?????
The inlet aleady has VVT, so you wont want to change the cam gere there. All you are really looking for is a cam gear for the exaust cam, then a few hour on a dyno to adjust it and tune it all in properly.
I'm not sure you will see any geat improvements if the rest of the system is fairly stock, the benifits would be more evident if you had changed cams, turbos and to some extent the ECU. I think you would get more bang for your buck if you were to change to the tomei poncams. (and/or the dump pipe)
robo
stage 2
=187rwkw, i meant all the mods before that on my stock car = 187rwkw
in three weeks time ill have these mods on and ill let ya now how i go, as i said i hope to achieve the 200-220 rwkw area
i know cams don't give you more overall power just more power at different points through the rev range, i was looking for something that gives me a more responsive motor down low
200rwkw is achievable on the standard turbo
but youd be pretty silly not to upgrade the standard turbo because in order to get 200kw out of it, you need to upgrade almost every other support system
IE dump/front pipe, exhaust, fuel pump, ecu + ebc, fmic etc
After upgrading everything to get 200rkw out of the standard turbo, all u need to do it buy a bigger turbo or get standard highflowed and youve got 220-250rwkw no problems.. next restriction being injectors ofcourse.
    • Impossible to remove the housing while turbo is installed on the manifold on the engine. So I have to do it anyways. I plugged it so there will not be any debris in there. Will vacuum aswell
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
