Hey folks,
I have a 2001 V35, with a sunroof. I'm also 198cm tall.
Since the sunroof opens internally, the roof liner is quite a bit lower in the sunroof model than the non sunroof model. I was wondering if anyone knows if it's possible to lower the seat lower than what the electronic controls will do it? (So I'm thinking take the drivers seat out and remove some spacers or something or take it into the local Nissan dealer and see if they can change the seat runners for something else).
Has anyone had this issue before and come up with a solution? I'd only need 1-2cm more room. I fit in it fine after work, just in the morning I'm slightly taller and it makes my head brush against the sunroof surround ;(
https://www.sau.com.au/forums/topic/460770-drivers-seat-height-in-v35/
no spacers to be removed and I doubt a nissan dealer would be interested in doing anything for you, especially being an import.
I think the options would be to have aftermarket seats fitted, or take it to an auto upholsterer and see if the can remove some of the foam padding in the seat base.
Edited by sonicii
If you've got a V36 then you can lower the original seat slightly :) I did this soon after I got mine as I'm ~192cm and have a sunroof. This is the guide I used.
V36 seat height/adjustment mod
Just had a quick search and found this one for the V35. Unfortunately it doesn't seem like you can get quite as much extra adjustment from dong it in the V35.
V35 seat height/adjustment mod - Look for post by GWord256 (#44) on page 3.
Thanks Heaps.
Mine was a little different. I didn't have that thick metal washer. Only had the rubber and the one with the lip. But i replaced the the other thin one that had the lip on it with a flat skinnier one and wound the nut back so it was just on.
Got a little more room for my head so im happy.
Thanks for that Fri_33! I'll have to try that next week :D (out of town for the rest of this week).
I couldn't work out a google term to find anything useful (including 'I don't fit in my V35 Skyline!'), but I recalled reading something about it being possible when I was first looking at getting the car, but hadn't been able to find where.
No probs, hopefully you can get some more room. Us tall guys have to stick together and try to sort out these issues. I ended up with custom rails in the R33 to get as much room as I could after trying a bunch of different seats :)
I forgot to mention mine is a coupe and I assume all the things I posted are for a coupe also. I don't know if sedans differ.
The only thing I would probably like is to get the steering wheel a little closer to me now. I haven't actually looked to see if there is a similar mod that can be done with that. I'm a little more cautious of messing with the steering wheel. Would have for shafts to disconnect or wires strip from it moving too far. I figure it works in a similar way with the steering wheel with the steering shaft having a spline to allow it to go in and out.
Mine is a sedan, but in one of those links was a series of pictures taken looking through an open back door, so it must work for the sedan too. That was something that I did like about my old Toyota Mark II (Chaser, x90), the steering wheel went up/down/back/forward and could pop up out of the way when you got in and out.
I also find it a bit odd that the instrument cluster moves with the steering wheel in the V35.
So, I've done it. In theory it works, but now rather than the seat hitting a stopper, it now hits against the left hand runner and can't go any lower on the left, but the right keeps going down. I've got maybe 1/2 a cm extra, if that.
Surely you would have sat in the car and tested everything before you bought it. So it's pretty much your own fault
Really?? Ever imported a car before?? Hard to sit in it when it is in Japan... I didn't realise mine had a sunroof until it got here. Pictures and description didn't reveal it. If it didn't have the sunroof, no problem.
  • Like 1
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
