Up for sale is my r33 skyline gtst series 1 automatic!
Overall this car is in great condition
Sunroof works great and great for this summer coming up
RB25det is in A1 condition! Always serviced on time
Engine is 100% stock! Never boosted! Only modification the car has is a catback exhaust
Body of the car is good for it age! There's a minor scrape on the passenger rear panel! Shown in pictures
With a nice polish the paint would come out mint!
Car is running pedders springs and shocks! Very firm
Yeah it's auto and great for daily driving! Auto doesn't slip or knock! Very good condition!
Always ran 98 octane!
Selling the car on Stockies with near new tyres
Can sell with the xd9s for extra
Car has rego till December 2nd 2015
Not selling with roady as I have no time!
$4500 firm with Stockies
xd9s are sold
Please feel free to contact me on 0428693525post-134219-0-02899400-1446633914_thumb.jpgpost-134219-0-67112500-1446633915_thumb.jpgpost-134219-0-72692000-1446633917_thumb.jpgpost-134219-0-63700800-1446633919_thumb.jpgpost-134219-0-93069300-1446633920_thumb.jpgpost-134219-0-66522700-1446633922_thumb.jpgpost-134219-0-76037100-1446633923_thumb.jpg
No time wasters please and no silly offers
Located Melbourne north
https://www.sau.com.au/forums/topic/460799-r33-skyline-gtst-series-1-auto-vic/
If this isnt sold by Mid december, the shell will be sold minus the motor. So will be selling a complete shell with exhuast for $2000. Genuine gtst shell with sunroof.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
