Hi all,
Some more parts up for sale.
4 x R32 GT-R OEM Wheels
Price $500.00 (pick up in Melbourne only)
Reason for sale: upgraded to Alpha Omega Racing EVO Brembo Brake Kit so these will no longer fit
Notes:
  1. A few chips and gutter rash as shown in the photos below.
  2. Tyres are not great (you can have them for free!)
  3. Centre-caps are included
Wheel 1:
Wheel 2:
Wheel 3:
Wheel 4:
R32 GTR OEM Front Indicators
Price: $150.00 (will post at buyers expense or pick up in Melbourne)
Reason for sale: replaced with smoked indicators
Notes:
  1. Includes plastic indicators and bulbs only
  2. Wiring loom and sockets that hold the bulbs in place are NOT included
  3. Tabs are intact
R32 GT-R OEM Front Brakes
Price: $250.00 (will post at buyers expense or pick up in Melbourne)
Notes:
  1. I believe that the rotors are RDA and not the original OEM but not 100% on that
  2. The pads are shot and need to be replaced
  3. I will have the rear brakes available once they have been upgraded to the Alpha Omega Racing EVO Brembo Brake Kit
Please contact via PM for further details.
Cheers
Rob
R32 GT-R OEM Wheels sold pending collection/payment.
A couple more photos and details for the indicators to provide feedback for questions that I have received:
  1. They are in pretty decent condition but that is subjective I guess when compared what you currently have / looking for.
  2. All of the tabs and guides are intact.
  3. The rubber seals are intact
  4. There is a split on the right indicator tab near the screw hole - note that this will not prevent it from being screwed securely into place.
  5. There are a couple of stone chips and a few marks on them
  • 1 month later...
  • 3 weeks later...
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
