Hello
The time has come to sell my R32, build thread can be found here
http://www.sau.com.au/forums/topic/448370-jordys-r32/
I am pricing the car at $15,000, or $14,500 BYO Wheels, negotiable.
I am not interested in swaps.
I've been working on this car for a long time, and would love to keep it, however work has taken hold and I hardly ever drive it.
Mods are as follows
Engine
- Rebuilt RB25DET (OEM Rebuild Head and Block) sourced from an R33 Skyline
-- Rebuild included, brand new pistons, Rb26 rods, neo block, and crank
- Tomei Poncams
- ACL race bearings
- ARP head studs
- Timing belt kit done with rebuild
- RB26 cover set
Intake
- Greddy Plenum
- Greddy Throttle Body adaptor
- Greddy Intercooler
- Apexi Pod Filter
Exhaust
- OEM Cast manifold
- 3" Stainless dump pipe, modified with a flex joint fitted
- HKS 3" Mild Steet exhaust, (claimed to be an option for a GTR - Got it for an absolute bargain!) Modified to fit GTST (hangers) sounds fantastic
- Catco High Flow Catalytic converter
- Nissan OEM and FRUSH gaskets
Turbo
- Hypergear High Flow turbo
- braided oil and coolant lines
Fuel delivery
- Tomei Fuel Pressure Regulator
- Aeroflow Fuel Pressure Gauge
- Aeroflow Lines and fittings (400 Series)
- Plazmaman Fuel Rail
- Bosch 725cc Injectors (top feed)
Electronics
- Z32 Air Flow meter
- Tomei Z32 Air Flow Meter Plug
- Apexi Power FC ECU
- Apexi type EL hand controller (o-led version)
- Greddy OLED boost controller
- R32 GTR gauge cluster
- Innovate Lambda gauge
- Splitfire coilpacks
Drivetrain
- Healthy RB20 box
- Brand new nissan Clutch master
- GKtech Braided clutch line
- Brand new Nissan Clutch Slave
- NISMO reinforced clutch pedal bracket
- NISMO Clutch pivot ball
- Exedy HD clutch kit
- Tight LSD
- HSD monotube coilovers
- I also have a spare subframe which can be had with the car, it has had weld in reinforcement plates installed
Interior
- Nardi Deep corn steering wheel
- Nismo gear shifter
- Bride Brix 1.5 drivers seat
- R32 GTR Passenger seat
- R32 GTR Rear seats
Exterior
- Genuine plastic N1 R32 GTR Front Bumper, including lower lip, vents and intercooler mesh
- R32 GTST Skirts
- R32 GTST Rear Pods
- R32 Aluminium bonnet
- N1 R32 GTR Rubber bonnet lip
- Genuine plastic R32 Grille
- Genuine R32 Rear Spoiler
- R32 GTR indicators
- R32 GTR projectors modified with black inner housings
Wheels & Tyres
ENKEI RPF01
17 x 9 +22 All round
Khumo KU31
235 - 45 - R17
75% tread all round if not more on the back (recently replaced)
NOTES
This car isn't a show car, it does have some issues in terms of paint, currently the front bar is cracked, and the drivers door is blue. I do however have a brand new N1 GTR Front bar and a lower lip in great condition which can be included in the sale. I feel the car is priced accordingly however am open to offers
All parts listed are genuine and/or real, service items are genuine nissan purchased through kudos motorsports with receipts
The car made 250kw with an HKS GTRS thanks to DVS JEZ, and that turbo has since been replaced with a hypergear High flow, the car is yet to be tuned on the new turbine so i am currently unsure of power levels, however could easily push that figure, if not a little more. This car is ready for big power with a fresh engine and quality parts however I'm not in the right position in my life to be going down such roads
It will be a real shame to sell, however my job is more important and I hardly ever drive this, which is a real shame.
I also have a large folder of receipts with most if not all parts, and services carried out such as engine rebuild.
Feel free to PM me, or message me on 0416 six three seven 980 with any questions, or picture requests.
Thanks
  • Like 1
https://www.sau.com.au/forums/topic/461712-for-sale-rb25-r32-coupe-nsw/
Mate, this is big mistake, you gonna regret it in years to come... trust me... :ph34r: these cars are too good to sell off doesnt matter how often you drive them... resist it!!
Edited by AngryRB
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
