"All imported vehicles with a magenta (purple) compliance plate whether from the ACT or another jurisdiction must be inspected at the Dickson Motor Vehicle Registry."
That is from the website. I think all Skylines and Silvia's have a purple plate - so no matter where you buy it, to transfer rego to your name in the ACT you would have to go to Dickson. I think we all agree here.
So the consensus is:
FMIC should be fine, even with hole cut through battery tray.
Pod should also be fine if held properly.
Boost controller will need to be hidden.
Any issues with the MCA coilovers? They aren't too low or something?
And one other point: I was thinking of having the car checked by some mechanic that can report to me. I inquired with Stateroads and they charge 290 for a report - its 6 pages and basically is a tick for satisfactory or not satisfactory for a list of things. Mainly it will point out a more major fault. Is it worth going with them or is there a better/cheaper alternative? I would like a check for the peace of mind.
I had paid for stateroads to do an inspection for me. Well worth the penny. It's a full report from paint correction to to rust to mechanical issues. I would use thees guys whenever I buy a car over $10,000+. Ease of mind and you know what you're paying for instead of calling their mechanic for a bias opinion. GL.\
I still have the report for my car - If you'd like to check it out. Give me a PM with your e-mail address and I'll send it over.
Edited by RosieR34
Have you considered asking the seller to drive the car to the Dickson pits for an inspection to see if it will pass before purchasing? I know it will be a hassle but for Sydney sellers might be worthwhile giving it a go so that you purchase knowing for sure. Might be an idea to look into an adm s15 instead as pretty much most things will be parted out that was different probably with the exception of rear window wiper and the digital climate control unit. Just a thought to save you more hassle than required.
Yeah I might ask him if he has plans to come down. Probably won't happen though.
If the car is mechanically good and history is clean then I would be willing to cop a bit of hassle. But really I am wondering why Dickson would make life so hard? It's not heavily modded.
Is hiding the boost controller really hard? And if the FMIC fails then I have to go stock? All else shouldn't be an issue I feel.
And I know the pains of not going back within their 28 days (or whatever the fk it's been reduced to now, allegedly) and having them discover things they glazed over the first time - blindingly obvious and ridiculously irrelevant things - resulting in another failure even though I fixed the issues from the first one. Kents.
Wondering what people's thoughts are on amount of boost. Stock S15 turbo (T28 ball bearing I think) running around 12-15 psi of boost. Would you get concerned about the longevity of the turbo - or is it pretty reliable? What sort of numbers do you all run (on Skylines)?
Also has anyone got a power brace fitted?
S15 stock turbos will happily run 16-17 psi but can't hold that till redline. They usually drop to around 14-15 psi in the top end. This is when your ecu is tuned otherwise 12 psi max.
In skylines most guys with aftermarket turbos run 18-20 psi. Some push them a bit more.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
