Hi Everyone.
Welcome to the WA Group of Skylines Australia. Feel free to introduce yourself and post a picture of your car.
I'm looking at getting some meets or events happening, so if anybody is keen please post up here and keep an eye on the "Events" section on the WA forum.
What do you guys want to do, a breakfast meet, or a cruise or a bit of both?
We may look into attending show and shine events too if you guys are keen.
If you are interested please post up.
https://www.sau.com.au/forums/topic/462648-welcome-to-sau-wa/
We used to do a breakfast in the city the last friday of every month but that was due to a lot of the regulars working in or around the CBD, I'm not sure where people are working these days though.
We could do a Sunday morning breakfast, probably somewhere central but not in a too built up area near the city so we can park our cars and look after them while we eat preferably which is not always possible with food places, but would anybody be up for something like that?
I'm open to any other suggestions such as activities, car related things, be it show and shines or other things.
I might also add this thread could be a good place to introduce yourself and post a picture of your car, so please show us what you got whether it's a GTS a T or GTR we want to see them all.
Edited by RB335
Have you all given any more thought about the cruise on the 28th boys?
Not particularly, I'm in Sydney ATM and fly back tomorrow. I'm going to One Day Sundays in the arvo at the Rosemount but could still make brekky somewhere.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
