Removed due to upgrade/replacement. Haven't fully separated/cleaned things up yet. Can take more pics as needed.
Complete hot side, manifolds to muffler including.
- Tomei Expreme Stainless Manifolds - $800
- R34 Stock manifolds - $100
- Stock manifold shields - $20
- R34 BB Turbos with drains and actuators (80ks on these, some shaft play, can take video/open to inspection) - $250
- Tomei stainless dumps (v-spec compatible with EGT port). $600
- 2.5" into 3" front pipe, with flex pipe. $200
- 3" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. - $600
Or take the lot/most as a complete system and make me an offer.
R34 PowerFC LJetro with hand controller (with tune for stock injectors/turbos) $800
R34 Standard fuel pump. $50
R34 AFMs $100
Standard mirrors in KR4, plug removed. $100
Standard Cam Gears. $20
Twin turbo pipe. $100
Rays vinyl wheel stickers, full set. - $30
I can assist with fairly cheap postage or pickup is fine.
Located in Wodonga.
Price drops, buy buy buy.
- Tomei Expreme Stainless Manifolds - $500
- RB26 Stock manifolds - $80
- R34 BB Turbos with drains and actuators (80ks on these, some shaft play, can take video/open to inspection) - $SOLD
- Tomei V1 stainless dumps (v-spec compatible with EGT port). $500
- 2.5" into 3" front pipe, with flex pipe. $180
- 3" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. Came of 34, but will fit 33 with minimal mods - $500
R34 PowerFC LJetro with hand controller (with tune for stock injectors/turbos) $700
HKS EVC6 - $400
R34 AFMs $100
Twin turbo pipe. $80
You know you want to throw me some offers and buy lots of this stuff at once and get a deal.
As much as I want to clear up space in my shed and put some money back in the bank :D
  • 1 month later...
Only stock bits and the cat back and front pipe left now.
R34 AFMs $100
Stuff will go cheap, just want to clear up space.
Also have plenty of S13 stock bits left over also.
Price drop, list update.
R34/RB26
- RB26 Stock manifolds - $60
- Stock manifold shields - $10
- 2.5" into 3" front pipe, with flex pipe. $150
- 3" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. Came of 34, but will fit 33 with minimal mods - $400
R34 AFMs $100
R34 Non Vspec air guides for brakes. $300
R34 GTT Console ilid skin, mint condition. Hinge and leg no good though. $100
S13
- S13 CA18 Viscous Centre and 6 bolt shafts - dunno what these are worth$$
- GKTech V3 S13 to s14 toe arm adapters (use S13 arms in s14 subframe). $Not sure either
- Carpet
- Roof lining,
- Lots of interior plastics
- Interior light
- CA18 Cam Gears
- CA18 Intake Cam
- CA18 AFM and plug.
- a TPS
- Washer fluid bottle and neck
- Standard space saver.
- CA18 carbon canister
- Rear toe arms
- Rear camber arms
- Coil pack cover
- Leaking power steering rack that includes the rack ends (the rack ends might be S15 ones as I used an S15 rack and some bits from the S13 rack ends/tie rods.
Or take a bulk lot for cheaper.
Located in Wodonga.
  • 4 weeks later...
  • 1 month later...
Bump, make some offers, need the shed space :)
34/RB26
R34 AFMs $100
S13
- Carpet
- Roof lining,
- Interior light
- CA18 Cam Gears
- CA18 Intake Cam
- a TPS
- Rear toe arms
- Rear camber arms
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
