R34 Stock And Performance Parts Clear Up.
Greddy air divider, plus i forgot to update this with new prices as i just want this stuff out of here.
R34 GTR/GTT/RB26 -
Greddy air diversion panel - $80
2x Stock manifold shield sets - $10
2.75" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. Came of 34, but will fit 33 with minimal mods - $150
R34 Standard fuel pump. $40
Standard Cam Gears. $10
R34 Non Vspec air guides for brakes. $100
R34 Console lid skin, mint condition. $50
Universaly catch can, properly baffled with sump drain, was $200 new, No hoses $140
S13 - Free/6pack/whatever
S13 CA18 Viscous Centre and 6 bolt shafts and diff cover.
S15 crown wheel.
Carpet
Roof lining
Interior light
CA18 Cam Gears
CA18 Intake Cam
S13 Subframe, bushed tired but no cracks.
TPS
Washer fluid bottle and neck
Standard space saver.
CA18 carbon canister
Rear toe arms
Rear camber arms
Traction rods
S13 and S14/15 RLCAs.
S13 Castor arms
S13 and S15 Tie rod ends.
  • 9 months later...
 Share
    • A31 is pretty much the same thing without HiAIDS I mean CAS, no improvement lol. Not to late to send it.
    • Thanks for all the replies! I also wanted to ask if wheels that were fitted on Ford Falcons would fit the 350GTs as well? In the area I'm at there aren't that many options for secondhand wheels and new ones here are way out of my budget. From what I've seen, most of the wheels that are available that were fitted on Ford Falcons have an offset of +33 to +36, with a centre bore of 70.5mm whereas the stock 350GT's ones are 66mm, can't seem to find any hubcentric rings that fit that difference though.
    • 215/45/18 tyres are probably a little on the low side compared to the factory tyre, it should be closer to a 245/45/19, which will get you about an extra 11mm of height, and should make you speedo read a bit closer to reality. 245/45/19s will be a bit too far the other way and you risk a speeding ticket as your speedo might read slower than your actual speed.  245/40/19s would be correct if you are going to 19in rims, they will give you a similar total diameter to the 245/45/18 tyres.
    • That's something I forgot to put in my list. The aggressive anti-squat in R32 is a f**king menace. I still need to decide if I'm going to drag the subframe out of my car and weld in the GKTech corrector kit. The main reason to dither is the need to switch to spherical joints in the lower arm to account for the twist induced in the rear pivot caused by lowering the front pivot. And yes...we do put better subframes in R32s, and I wish I'd gotten an S14 one instead of an A31 when I did the "take off and nuke it from orbit" HICAS delete all those years ago.
    • I have been looking at some setting on the alarms for the Q60 and what buttons do and so and also been looking for details on the alarm in my V37 which is a standard issue with the car. settings like window roll up and a few others seem to not work at all. i cant seem to find exact info on V37 alarms so Q60 is all i can really go off i have not tried 400Z alarm settings or info yet so that will be next. any one got like a sheet of info on the alarm system in the V37 as all my documents are in japanese but i thought the system would basically be like standard through similar models?
