ummm no i dont have pics atm, but i can get em!! it's alot of work though.. i describe it to you!
series 1 GTST --
where the hazard light switch and demister switch were i have an air/fuel ratio and water temp guage! both are the smaller autometer guages
then on the other side where the mirror switch is there is a boost guage! larger style autometer!
then all switches have been moved to the center console!
I might just put it back on the base of my A-pillar. It really is the best spot for it. I'll get defected for my exhaust before I get defected for my boost gauge anyway...
The gauge I have in my dash already is completely blocked by the windscreen wiper stalk. I have no idea why it was positioned where it is. :confused:
i'll get photo's of mine tomorrow, and post em up. i only use my boost guage if i suspect something might be happening with the feel of the cars acceleration.. not something that i constantly look at!!
on the pillar is just easy to spot when driving past etc!!!
if you have them in a pod, they are less likely to pick it up unless they go over your car.. but if you have cups and open guages they see em when you drive past etc... been done twice when i had some on the pillar! (granted it was a monsta tacho and boost- but it looked good)
I've got mine on the A-Pillar, but if a cop ever tried to defect me for it I'd get pissed off, cause the way I see it, taxis with their souvalaki ordering system thingy are just the same! But the government has different laws for different things I suppose... funny how the law works against you!
sorry for the large image but i cant be assed downloading the file and reupping it to my webspace.
i have mine located on the steering column, passed registration fine.
front view
side view
hey where did u buy that gauge holder from and how much...thats the best idea ive seen so far ....
it came with the car when i imported it so I have no idea unfortunately.
its a piece of carbon fibre shaped/cutout around the top of the gauge, its quite a tight fit and it holds it in there very well. the fibre is then simply screwed to the steering column with some 90 degree angled pieces of metal.
The gauge itself sits in a small cup.
its quite simple and does the job perfectly and is in perfect view without blocking any dash gauges at all.
Shaun
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
