  • Replies 42
The rb20/26 inlet cam gears bolt on the same a the exhaust ones (4 bolts) but the rb25 has one large hollow banjo style bolt that holds the vct gear on.
So without modding the center of the cam aswell as the front bearing surface the stock vct gear wont fit so you need the rb20/26 pully.
John
surely if you put gtr cams onto hydrolic buckets your seat to seat timing would be increased to the point that idle quality will suffer, unless you plan on letting the buckets pump up and running a lash setting that match the gtr cams,  18 thou or something like that.
Not actually correct as the hydraulic follower allows clearance, due to the timing of the oil inlet, but let's just say it doesn't....
Then you end up with 18/1000 extra lift, this is not a bad thing :rofl:
And you end up with longer duration, again this is not a bad thing :D
I really can't see a problem, an RB is not a an old style engine with the hydraulic lifter at the opposite end of a push rod. :D
Just interested in discussing a recent incident with an RB20 that fitted GTR cams. The owner believes some of the inlet valves were staying open off lobe. So would the problem be:
1. The hydraulic follower is pumping too far open
2. the extra lift is pushing the follower too far into the guide and making it stick(the engine is 180K old), I think unlikely. it would stay well open.
3. the off lobe diameter of the cam is a larger diameter than the stocker and the hydraulic follower is jammed at one clearance and won't close to accomodate.
4. bent valves due to timing belt slipping a few teeth as the inlet cam was apperently very tight in the journal.
There were signs of at least one set of valves touched the piston so the timing would have been out slightly, but at least 3 sets stay slightly open. I'm yet to see the head but very keen to follow up and see if they ar all bent valves or one of the other problem I mentioned.
  • 3 weeks later...
  • 3 months later...
We are doing this conversion but modifying the inlet cam to run the VVT. May be crap but costing nothing to find out so will let you know.
This is on GTSt VSPECs GTS that has 450rwhp on the Stock cams so should be an interesting test.
Has these been done yet??
Any results available?
I have 3 sets of GTR cams and would like to put 1 set in my RB25det if it is worth while.
Save your energy guys, this swap does NOT work.......GTR cams are designed with ramps suitable for .015"-.018" clearance with solid lifters. Put them in a hydraulic lifter engine (RB20-25) with .000" clearance, and you now have longer duration, but ultra-low lift for a fair portion of that duration! Result = bad idle vacumn, crap power, etc, etc.
With that said, I do have 2 sets of GTR cams for sale...$200 per pair, so if you still want to try this swap, knock yourself out. :kick:
B.
Which is why it works for Sydneykid, and the suggestion that it wouldn't work due to ramp angles was laughed at by one of the Northsides' (Melb) better engine machining and building shops.
So you will of course provide dyno charts to support this advice? Make it quick as I'll be limited to occasional whoring from Thailand from 12 tomorrow.
I'm more than happy to concede to concrete evidence that it won't work, but there is evidence to the contrary.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
