We had a couple at the last drift comp in WA, and the number of competing Cefiros in the next comp will be double that of the last. Its progressing :) I bought a lot of spare parts with my car too. A few sets of front ends just incase :D
JK
  • Replies 151
I'll be stoked to see more cefiros out there. I have a ceffy and a Sil80 but i think the sil80 is a better drifter, hence me using that for drift events and the ceffy will be the cruiser.
I have also considered bringing another cefiro in for drift purposes and selling the sil80.. but probably won't cos of excess laziness.
Anyone have a passenger side front blinker assembly spare? also passenger front seatbelt... i need both for rego/compliance
Hi guys,
Heres mine.. some people have already seen the pics but for those that havent theyre located here: http://www.aussiewheels.com/profile/View.p...&PhotoGallery=1
Specas are also located on that site and not all of them are known as yet.
Mark i believe you got urs thru meggala yeah? i seen the pics of it doing the qtr :P very nice...
I will be using mine as a circuit/drift car as its already setup that way.
Its currently sitting in the Brisbane docks ready to be deported :P to melbourne.
The brown turns me off a little.
jaik, what model does it say on your build plate? the trim in yours looks quite different to the ones I have seen.
I havent got my car yet. But its a CA31 (bah bloody hicas) but it is a black/gray interior. I have attached my vehicle information from the Nissan FAST software and it doesnt show me the interior trim code ;(
JK
i probably would have preferred a grandads car, but mine appears to have had suspension before and a drivers seat. no sign of any guaging however, so i dont know to what extent my car has been thrased. its had a manual conversion so i presume the clutch should be half decent, and i can only dream that its got a 25 box in it (harsh reality of it being a 20 box, hopefully a turbo one -anyone know how to tell the difference?) and I suspect a standard LSD is in place too. Ah well Im throwing a couple of grand at it to handle better (ie to aid in recovery from driver error) so she'll be right mate.
JK
I seriously doubt you would have got a 25 box, but i think that the 20 NA box and 20 turbo box are probably the same strength with different ratios on a couple of gears (similar scenario to SR boxes)
If you will be drifting the thing, you will need better than the standard LSD.
JK
Let us know what specific model it is when you get the car... be interesting to tell the difference between (from what I have read) the VL, SE, VE and SE-t models.
Yeah dont worry, I plan on documenting EVERYTHING I do on the car to help the rest of the new Cefiro owners. Every mod I do, every factory thing I butcher, everything will be on my website. Lots of pics too! I might even get game and post all the microfiche for the A31 series aswell.
JK
I plan to immediately do timing belt, cams, sprockets, water pump, o2 sensor, ecu water temp sensor, fuel pump, gtr injectors, coilovers, z32 brakes etc so I guess even though its been documented before I may aswell do it again. Who knows, someone might find it useful some day.
JK
The stuff I have sitting at home for mine for after compliance include:
SR20DET+5speed (s15 turbo, stainless manifold, 550's, emanage, bb clutch)
FMIC
Trust whiteface electric guages (boost, oil press, oil temp, water temp, exh temp)
Bride seat + rail
alloy subframe bushes
Should be ok once done
Hi Fellow Cefiro owners. Hey any sydney/NSW owners in here?.. Maybe we should hook up and compare notes stuffa sthere arnt many of us here in NSW. I imported my car from Meggala as well. Top bloke he is the guru on these cars and has helped me with getting parts minor problems and stuff even after I got the car till now back in march.
Specs/Mods are as follows:
- 1988 A31 cefiro
- Rb20det
- T3 Turbo off an VG30
- Mech Diff
- Boost Guage
- GFB Bleed Valve
- Larger Cams
- HKS POD
- Turbo Back 2.5 inch zorst
- Tien Height/Camber Coilovers
- A few other minor mods
I dont mind the brown interior too much.
BTW i have an stock cefiro air box I HAD to buy for 250 bux just to pass the blueslip here in sydney so if any of u guys need to borrow it in the near future then let me know.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
