  • Replies 151
lol u serious? i was looking a that a week or so ago trying to convince my gf to learn to drive manual :) nice work mate and at that price its a bloody bargain, specially with the mods!!!
finally got mine registered on saturday... car feels very light... :) (i'm used to the weight of 33 gtr... hehe) only annoying thing atm is that the driver side sun visor has no clip and it keeps on banging my head... :)
plus, stock exhaust looks like a set of chopstick... hehe
couldn't be happier with the car...
I got the cefiro on the weekend finally! first thing I did after my 2 hour rego (bloody rta poindexters) I forked out for some audio gear and spent the weekend ripping apart teh interior and putting it all in.
very happy with the cef, it drives beautifully and cleaned up very well.... after 5 hours of labour.... man there was a lot of crap in the door jambs...
result: I found a couple of yen coins, a flare that quickly got burnt and lots and lots of old audio cables... attached to nothing but left in the dash and under seats.
the cef feels very light (great power steering) and has a very comfortable interior... I am surprised in all I have read online about cefs that no one really mentioned how cruisey these cars are inside, I have a blackish interior but it seems to be tinted with red from sun rays over time... odd. I didn't realise from the dealers pics that the white paint has a pearl effect through it? does everyone else with white cefs have that? I couldn't tell if it was post purchase paint...
i was gonna but a bid on that car hehehe. you beat me to it god damn it. hahaha that car is mint though congrats on your buy.
how much did it cost to comply? if you dont mind me asking
u talking to me? anyways, if you are, it cost me $2376 to comply + blueslip... there were some extra stuff needed for the car.. the car was missing a cat, the front suspension was cut in half, aircon wasn't degassed, hks filter needed a new element.. etc.. i would say if it wasn't for these little things, the cost would've been alot cheaper..
mine has pearl over white but mine was a respray job... don't know if that colour was available on factory white...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
