Hi All,
Thought I would post up some details on my recent purchase. Have been a member on these forums for 14 years, though disappeared for a while when I sold my old R33 GTST around 2004.
Have owned a few cars since then, such as an S15 200sx, which I kept relatively stock. Followed by an 11 second XR6 Turbo that had a few bits & pieces. My last car was a 2007 BF FPV Super Pursuit ute, which was supercharged, cams, water / methanol injection, etc.
I relocated to Perth from Brisbane last year and decided to sell the ute, at which point I missed not having a performance car, so decided to go down the R33 GTR route. I looked at a midnight purple one on the Sunshine Coast before I left, which was described as 'good condition', only to be found to have lots of body filler in the passenger door, no air con compressor and a pair of HKS GTRS turbos that surged..... I then looked at one here in Perth, which presented fairly well, though had a leaking rear main seal, and before I left the first viewing, the owner informed me that it was leaking oil into the coolant. I obviously passed on this one, and subsequently saw it appear on Car Sales at a Dealer (hope that leaking head / gasket was fixed....).
So I looked at a 1997 Series 3 in February, which had a few mods and checked out well. I decided to make an offer and a week later the car was mine.
Details are:
1997 Series 3 R33 GTR
KR4 Silver
Power FC djetro
Nismo clutch
Greddy intake kit
Nismo suspension
Nismo fuel pump
19x10 wheels
-5 turbos
Alpine sub and amps (not sure whether I'll keep this...)
Overall the car is in excellent condition, and happy with the purchase. My plans are to just to maintain it well, and enjoy it on the weekends. Not going to go crazy with engine rebuilds or bigger turbo/s.
I'll be posting in here what things I've had to replace / repair along the way, which will serve as a bit of a journal.
Hope to eventually meet up with Perth based enthusiasts at a track day or meet.
Enjoy the pics.
  • Like 6
https://www.sau.com.au/forums/topic/464116-r33-gtr-series-3-perth-wa/
First thing to resolve on the GTR was a strange whirring noise when the car was at operating temp and why it kept destroying power steering belts. After a bit of investigation, I determined that the noise was coming from the timing belt and the aftermarket Ross harmonic balancer was not aligned correctly to the power steering pump pulley. Knowing how serious a problem could be in relation to the timing belt, I booked it into a local workshop and they began looking into the problem.
1. First problem was that the timing belt was way too tight.
2. The Ross performance harmonic balancer was from 2012, and has a known alignment issue.
3. Who ever recently replaced the timing belt, failed to inspect and replace the leaking crank and cam seals, so they were leaking.
4. The previous owner obviously took the cam covers off and painted them red, though decided to use standard set screws to torque down them down. This caused the gaskets to be pinched and started leaking.
5. The half moon key way on the front of the crank was also damaged. So this was cleaned up and replaced.
All of the above has been rectified by doing the following:
1. Get rid of shitty Ross harmonic balancer, and replace with Nissan OEM item.
2. Replace cam & crank seals and cam cover gaskets & bolts / washers.
3. Fit new idler / tension bearings and Nissan OEM timing belt
4. New key way
There is a valuable lesson here, and that's if you're contemplating to attempt this type of mechanical work and you don't know what you're doing, then take my advice and leave it to the professionals.
Decided to paint the mesh on the front grill today. Annoyed me that the paint was starting to flake off to reveal the steel underneath. Bought some pressure pack black, masked it up and gave it a few coats.
Also had a play with the hard wired Bel STiR Plus radar detector. Nice bit of kit, and one of the advantages of living in WA :)
  • 1 month later...
Absolutely loving this car. Completed a performance driving session here in Perth over the weekend. Gave me the opportunity to stretch its legs. Car performed flawlessly, though have notice it has a tendency to understeer. Might have to look into this a bit further.
Next step is to take it to a proper track and give it hell.
  • Like 1
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
