Hi guys'n'gals
Thought i'd post in here rather than general, bit more performance orientated. Basically need a few pointers with exhausts. Been looking at batmbl's front/dump pipes, heard good things and looks like a good price.
If those are installed, do i then need a new CAT/rest of exhaust (not sure what that's called) to go with them?
I know a free flowing exhaust is a must for a turbo car, but i imagine there is a limit regarding how wide an exhaust should get? I'm not looking for a shelter for the homeless exhaust. So in terms of response more specifically bottom end, what size an i looking at? 3", 3.5" all the way through? Larger/smaller?
Not really performace question but more final look of the exhaust, which i guess will limit me in brand choices, but i'm after one that doesn't.
- angles up/away
- angles down (WRX style)
- trumpets out (tip)
- sticks out too far from rear bar.
I dunno, something about exhausts shape not suiting the car really puts me off. I'm sure that's probably going against performance, but would it make that much of a difference to rule out the above style exhausts?
Lastly, they seem to be a hollow piece of steel, so are there really MUCH better brands than others? Obviously not going down the titanium route, but something in the style of the Mines R34 GTR exhaust looked nice. Finish pretty flush with the rear bumper and was parallel with the ground, not all angled funky. And if it's good enough for the Mines car, i'm sure it will be fine for my GT-T (minus the titanium-ness :P )
So yeah, long post but just any brands or exhaust models that aren't like the above mentioned, and what are the best specs for getting better response, not top end.
cheers.
https://www.sau.com.au/forums/topic/46447-r34-exhaust-advice/
Regarding power curves.
The majority of the shaping of the power curve is going to come from the engine pipes, not the exhaust itself. On an NA car, the exhaust plays more of a part, becuase you are talking abuot pulses etc. On a turbo car, the impeller gets rid of the pulses and turns them into spinning air.
The best bet with a turbo car, is to get the biggest from the turbo back as possible. and especially right at the outlet of the turbo, because pressure differential between the sides of the impeller wheel plays a big part in boost response.
On a turbo car, the less back pressure, the better.
I'm not sure about the exhaust versus power equations, but I don't think I will ever be needing a bigger exhaust then the one I have (Fujistubo, Power Getter). I think its 3" or a little bit over.
The ultimate front/dump would be the CES Racing one which is split for about 40cm until just before the cat
Then a BATBML big arse cat
Then a full exhaust then there on.
Couldn't go too far wrong with most exhausts as they are all pretty much straight through anyway.
Are you coming tonight?? You could have a good look and listen to mine if you want.
BASS OUT.
I didn't even realise that the meeting was on, just saw the thread today :D
How much are we looking at for the CES Racing one? And it looks like there are 2 BATMBL cats, one small, one large. Would the small one be ok for GT-T?
