I have a few bits from a RB25DE NEO strip down.
Rear Wheel Drive NEO RB25DE engine block, including crank, rods, pistons. Crank and bearings are great, but the pistons have suffered shrapnel damage. Block will need rebore. $350ono.
RB25DE NEO Head, includes cams, solid lifters, exhaust cam pulley $350ono.
Slight damage to combustion chamber edges, valves appear OK.
Y33 Cefiro engine mounts (the rubber bits) suit AWD RB25DET $40 pair
R33 Skyline engine mount brackets (the alloy bits) $40 pair
R34 RB25 NEO coil packs, $50ea or $200 for the 6.
R34 RB25DE NEO injectors and fuel rail $150. A46-00 markings, red top
Y33 Cefiro AWD sump and diff. 4.08 ratio. $350ono.
All located in Cardiff NSW, All negotiable. Happy to post smaller items.
Best contact by phone 0418397017. Ben.
I also have an R33 Series 2 Wiring loom and ECU. I have stripped the tape off the ECU end of the loom in the process of using it for a conversion, thus the un-needed bits are gone. I have labelled the useful wires. VVT plug broken, but otherwise OK. Includes coil and injector harness. $200ono
Y33 Cefiro engine loom. Missing the usual import engine bits as cut off by the wreckers. Does have knock plugs and the 6-pin plug for connecting to the main engine loom. $50.
  • 4 months later...
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
