Hi sadly I am putting my weekend car up for sale. I don't have time to enjoy it any more and would like to pass it on to somebody who does. ImageUploadedBySAU Community1461999694.103935.jpgImageUploadedBySAU Community1461999727.084737.jpgImageUploadedBySAU Community1462002086.207382.jpgImageUploadedBySAU Community1462002100.937847.jpgImageUploadedBySAU Community1462002110.620573.jpgImageUploadedBySAU Community1462002119.869591.jpgImageUploadedBySAU Community1462002129.654764.jpgImageUploadedBySAU Community1462002138.471342.jpgImageUploadedBySAU Community1462002148.489370.jpgImageUploadedBySAU Community1462002161.844207.jpgImageUploadedBySAU Community1462002184.095051.jpgImageUploadedBySAU Community1462002195.476543.jpgImageUploadedBySAU Community1462002213.111594.jpgImageUploadedBySAU Community1462002223.615603.jpgImageUploadedBySAU Community1462002238.548894.jpgImageUploadedBySAU Community1462002250.034700.jpg
- Cusco Coil overs
- Suspension in good condition
- comes with stock shocks as well
- Air pod filter(comes with stock air box as well)
- Boost controller
- Gets serviced every 4000 km
- Pioneer radio, usb, Bluetooth and CD player
- Kicker speakers
- 3"exhaust
- HKS big intercooler but stock inter cooler on the car at the moment
- alarm system with 2 remotes
- GTR body kit and front bumper and spoiler
- No leaks
- Under the engine, gear box and dif is dry and clean
- The floor of the car is extremely clean
- The car has had a new service
- Clear glass indicator light on the front sides( stocks red ones comes with car as well)
- The disks have been machined
- New hydraulic pump
- accident and rust free
- GTR strut brace
- Xenon headlights high and low beam
- Haven't changed the timing belt but was checked by mechanic and was okay
-Rego finishes on May
-The car has done 104000km
Price is $7000
Car does not come with Te37ImageUploadedBySAU Community1462002794.543834.jpg
Melbourne.
https://www.sau.com.au/forums/topic/464545-wts-skyline-r33-gtst-s151995/
  • 5 weeks later...
  • 1 month later...
  • 2 months later...
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
