Hi Everyone,
After looking around for quite a while for a bulletproof diff and cv combo for my silvia. I ended up purchasing 32gtr hubs and cvs, and searching for matching diff. Wanting to keep my ratio, i stumbled across a nismo gt pro 2way to suit 32 gtr, just the centre, and stub axles with bearings. I did some looking around and figured i can swap my crown wheel on, and chuck it in my housing.
Today i made good progress but am stuck at getting this center into my diff housing. It seems very tight and not in completely yet, with zero shims or spacers. Does anyone know if i have missed something in my thought process, or do i just need to keep shoving it in? My housing was originally a viscous lsd, r200.
Appreciate any advice! I am not a diff expert so may have missed something simple too....
The worst time I have ever had playing with cars in the last 6 years is f**king around with Nissan R200's.
Everything is close enough that it looks like it should work, but then it doesn't. If I was you I would find a 32 GTR diff, take the centre out of it and put your 2 way centre in it. Then just sell your housing and standard GTR centre.
Dicking around with Nissan diffs sucks.
  • Like 1
Did you centre come with half shafts? One example of how shitty R200's are; R32 GTR came with 3 different centres. 29,30 and 31 spline. So not only do you need the correct housing and centre, then you have to find correct spline half shafts.
  • Like 1
Yeah, it came with matching half shafts and bearings.
Completely agree re looking close enough but then just won't quite fit! Costs a lot of time messing around. I think ill take it to a shop today for a second opinion, but ultimately as you said buy another diff and see if it fits in there, and mod the front flange to suit my tailshaft. I considered trying to machine my housing out a bit but think it's a waste of time and money and still may not work
Yep modding your housing is a waste of time and money. At least you can sell it later if you just buy a GTR one.
You are in newy yeah? I have another R200 V-LSD housing you could try if you reallllly wanted to. You are welcome to come grab it and try. If not have a chat to Newcastle gearbox and diff. Have found them helpful in the past.
Thanks for the offer man really appreciate it. I am in Newcastle yeah, thought you were interstate for some reason. I think I am just going to buy a gtr diff and swap it all across. Hopefully can sell one of the centres again after its all working. The car is now stuck on someone else's hoist so I'll need to sort it relatively quickly.
I dropped it all to a mate who just took over a workshop so hopefully he can check the ratio and i can source something close. That was the other motivation behind keeping my diff - didn't want to change ratio if i didn't have to.
No worries mate. Jump on Facebook and search for East Coast JDM and get in contact with Dan Runken, he runs a massive warehouse at Redhead and should be able to sort you out with one
  • Like 1
  • 1 month later...
East Coast JDM are great - they looked through all their rear subframes for me when i wanted to swap from non-hicas to a hicas subframe (with lockbar).
Hey i'm in Newy too. I have a dodgy looking silver GT-FOUR r34 sedan, with a turbo stag motor.
  • Like 1
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
