Hi all!
I have looked through the forums and can't seem to find what i am looking for (also can't find anything i can understand well :sweat: )
A friend of mine had a head unit sitting around at his place and seeing as my current one doesn't have AUX connection capabilities i want to install it in my car. Im in need of a new project to attempt but have read that i might be able to buy adapters so i can avoid having to wire it in myself? I am new to all of this so was hoping someone could point me in the right direction. i have attached photos of the head unit, and the wiring that came with.
Sorry for the newbie question, but have decided to finally try and learn how to do it!
Thanks guys :thumbsup::thumbsup:
https://www.sau.com.au/forums/topic/464839-r33-gtst-head-unit-install-help/
GTofuS-T: thanks for the reply!
If I was to try and wire it up myself are you able to give me an idea of how to do that? I found a good diagram online to show what each wire is for and where it goes. Just don't know which of those two adapters I would need to do that. Would appreciate the help!
And just to confirm, when you say 'existing wiring' do you mean the head unit wiring or the car wiring?
I meant the car wiring, for example one of my cars had never been touched, so i could unplug the OEM headunit and plug the car wiring plug in the Supercheap plug I linked above, which converts to ISO, I was then lucky enough to have bought a head unit that came with ISO plug that would plug directly into it.
It looks like your headunit wiring is just wires at the end, so you would need the second plug i linked from eBay to wire up to the headunit wires that would then plug into the ISO to Nissan adapter into your car. like so: https://upload.wikimedia.org/wikipedia/commons/thumb/3/34/ISO_10487_connector_pinout.svg/220px-ISO_10487_connector_pinout.svg.png
HOWEVER:
If your car already has an aftermarket headunit in it, then it's likely that someone has already cut and wired in the current headunit so you won't have the nissan plug and will have no need for the Supercheap Nissan to ISO adapter.
The actual wiring itself you'll need to just research I guess, off the top of my head REd is 12V Ignition, yellow is battery, black is ground, grey and white are usually the speakers, but exactly which speaker is which will take some testing.
I'd say first step is to remove the headunit that's in your car and see what the wiring situation is behind there. Oh and watch that MCM video, I'm sure that will help.
Thanks a lot for the replies! I will pull out the old head unit tomorrow and see whats going on back there tomorrow. Might try and install the new one on the weekend, will be good to have music again! Appreciate the replies, very helpful :thumbsup::thumbsup:
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
