For sale: (NSW) Mitsubishi Lancer Evolution VI GSR
Price and price conditions: $15,990ono
Condition: Very good
Contact Details: Zero 431 083 394
I've been tossing up whether to sell or not but sadly I'm downgrading so the evo has to go.
It's been meticulously maintained by Indy @ IS Motor Racing since 2012 (full receipts for over $20k spent on it). No bad rusting like you see on some imports, and all bushes and control arms have been replaced.
It's a great car with no faults and with no more to spend. The clutch and tyres have been fitted just this year and rego doesn't expire till April 2017!
Year: 1999
Colour: Scotia White (original paint, no accident history)
Kms: 167000kms (serviced every 5000kms with receipts to prove)
HEL Braided brake & clutch lines
Brand new RE003 225/45/17
Exedy Cerametalic Clutch
Evo 9 Flywheel
front diff and gearbox service
Brand new rear control arms
Brand new OEM engine/gearbox mounts
Beatrush shaft bush
Brand new wheel bearings
Evo 9 Turbo
HKS EVC 5
Meek Full Piping Kit
Dixcel brake disks and pads all around
FIC 1050cc injectors
Evo 7 ECU + Tune
Shifter bush kit
Suspension and steering bushes replaced
Front tie rod ends replaced
Blitz alloy radiator
Meek suction pipe kit
Meek high flow cat
Meek 3” full turbo back excaust
Evo 8 MR blow off valve
New rear diff bushes
Ralliart front roll stoppers
1.5bar Actuator
New battery
Car is located in Rhodes. Slightly negotiable.
13217366_10153861140818089_5240554352045
13198522_10153861140848089_1971057314526
13198661_10153861141603089_1021459312197
13198658_10153861141468089_7410874892941
13260187_10153861142468089_7686792598821
https://www.sau.com.au/forums/topic/464930-syd-evo-vi/
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
