hi fellows,
i have HDi FMIC fitted with 2*12" thermo fans (controlled by davies craig digi thermo controller and IGN relay, not aircon reply.)
the problem is when the 2 thermo fans kick in when idle, then the idle will drop a bit with some vibration.
that's so annoying to me. any solution?
thanks guys
Edited by YangLIU
https://www.sau.com.au/forums/topic/465058-m35-thermo-fan-causing-low-idle/
Factory ecu's which use thermo fans automatically raise the iac valve pulses to ensure a smooth idle when the fans turn in.
You don't have that.
I can suggest nothing, except put stock fan back on.
the problem is factory thermo fan working logic is not suitable for aussie hot day. :angry::angry:
Can you pull in staged; one, then the other?
It's the huge load pulling both in at once that does it.
yes, the logic of digi thermo controller is pull the 2nd one after 5sec. the low idle is happening when the 2 fans running together after kick in
Why are you running 2? All of us currently run 1 without cooling issues (and i live in qld and dint have issues in middle of summer).
just want to make the engine be more cooler. i will wire one to stock thermo switch that will kick in with ac on and high engine temp
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
