Hello guys,
I have had an ongoing saga trying to fit a GTR centre into my R200 housing in S13. I have purchased a used Nismo Gt Pro, to suit 32 gtr, and went to fit to my R200 housing. I went with GTR centre due to swapping to 32 GTR 6x1 CV shafts etc on the Silvia. It didn't fit in the housing, so I bought a 32 GTR complete diff (non active diff) and tried that. The Nismo centre still doesn't fit in either my S13 housing, OR the 32 GTR housing. A comparison photo shows that the Nismo is approx 15mm wider than the stock mechanical GTR centre. I am wondering if anyone can identify what is going on?
Could the Nismo be from something else? Could it be to replace a 32 GTR active centre rather than mechanical and is that centre usually wider?
Any help would be appreciated.
Thanks
https://www.sau.com.au/forums/topic/465620-gtr-diff-centre-widths-32-vs-33-etc/
Had a look at the Nismo list. They list the same LSD for the R32GTR, R33GTR R34GTR and all R34s. They do not list an LSD to replace the active diff (which is not to say they don't make one). Do you have a Nismo part number for the Nismo diff and how reliable is the fact that its a GTR LSD?
Thanks for looking that up. I will have to see if there is a part number on it anywhere, currently it's at a shop. The guy I bought it off said removed from 32 gtr, and it came with stub axles/half shafts which are 6x1, which makes it seem to be correct?
Some Z32s have 6 x 1 axles and a wider diff head. (beaten to the punch)
25 minutes ago, IT15ON said:
Are all the z32s r230? Or could be an NA z32 r200 size?
My r200 crown wheel fits on it fine which is what made me think it's not an r230/z32?
No I think only the twin turbos had 230
I think we may be onto a winner here.  I'm not Mr Nissan, but I'm sure his engineers decided it would be easier to have the same diff housing and driveshafts on all the Z32s regardless of whether they had the big diff centre or not.  Hence you get a wide R200 centre.....
So now the OP probably needs to find a Z32 housing and possibly shorter driveshafts.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
