S2 GTS25T map sensed has chuggy weak idle and from time to time fixes itself up .
20 yrs old and not sure what to look for ie if there is something obscure these cars do at this age , 162K btw .
All cooling hoses rad pump and belts etc just replaced . Had a sticky around the IAC solenoid and hoses all seems ok .
Going in Tuesday for compression and if necessary leak down tests . Had EV14 conversion in recent past but problem didn't change .
Had Splitfires and new OE coil loom a while back .
Been running 33 GTR fuel pump for some time but not sure if it could be the issue .
Doesn't falter otherwise drives fine though can be prone to revs dropping far enough to stall occasionally .
Any suggestions , cheers A .
https://www.sau.com.au/forums/topic/465958-gtrs25t-idling-issues/
does it idle richer?
Are you on 98RON? if so.. increase the injector PW see how you go.
What is your fuel pressure at? is the stupid fuel pump relief valve inside the tank still? if so delete that junk.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
    • Going by the intake & injectors I'd be guessing it's a DE, check the head casting number, should be 5L8 on a DET, 5L7 I think is the DE number.
