Nissan R35 GTR GT-R Factory Alloy Wheels Rims 20" x 10.5" 9.5" 5x114.3 #2
Rears 20" x 10.5" +25 Offset
Fronts 20" x 9.5" +45 Offset
Tyres are Bridgestone RE070R 255/40 and 285/35 around 70% tread.
Email Winster John for more details
[email protected]
Price: $1300
Postage Australia Wide : $80
Guys, if someone joins SAU, then posts an item 40 minutes later that seems too good to be true, please don't pay them immediately before doing some serious homework. And if you are going to pay them, at least use Paypal ....
  • Like 3
For those who are worried about this member being a scammer:
I've contacted the owner for proof of ownership with spoon pictures.
This thread will be re-opened once i've received these photos.
:cheers:
  • Like 1
  • Trex locked this topic
