Hello guys, new here on the forum from Texas! Ive been in the nissan scene since 04'..Anyways, i have purchased a rb25 from the jdm importers over here.The motor seems to be great, until i turn on the a/c. I get a boil in the back of the motor that continues to boil the more i drive...Or if i shut off the a/c, boil will eventully stop once temp gets to 195f-198.. If i drive with the a/c off it will stay at 195f-198f.. If i drive with the a/c on it will stay around 210f-212F.. It never has shot coolant out to the reservoir, like a overheat condition... Tried multiple radiator caps.  Im aware of turbo thermosyponing boil after the motor is off...But, this boil i have is with motor running while i drive, if i really trash on it the boil will spread to the upper radiator hose, only with a/c on...IM STUMPED and i dont want another sr20 lol ..Please help me guys! :)
Heres a list of everything that is good. Headgasket, thermostat, new dual row aluminum radiator, Good clean condensor, condensor fan works fine , clutch fan, fan shroud, coolant 50/50 also tried 70/30 distilled.. heater core is good. Water pump is very strong..All hoses are new, no coolant leaks at all..Even added a bleeder valve on my heater core hose to bleed air..
Does have a freddy intake manifold with a new cometic gasket properly torqued down. No smoke in tail pipe, no oil in coolant, spark plugs are great..
Passed headgasket chemical combustion test and leak down test radiator/coolant system pressure test.
The motor works perfectly fine idles great, but i have a boil when a/c is on.
O yea forgot..ambient temps are 100f here haha
Edited by Orbea Occam Am
https://www.sau.com.au/forums/topic/466124-s2-rb25-boiling-in-coolant-lines/
Not using any water? These engines are notoriously difficult to bleed. Not sure what the a/c is doing but if you are using a Freddy manifold you are probably missing the front bleed valve that is there on the stock set up. What people do is jack up the front of the car and jam a cut off coke bottle (for example) in the radiator neck and keep filling with water as the engine warms up on idle.
Yes ive done this many times...ive tried 70/30 coolant mixture distilled water...installed bleeder valve on upper heater core hose
Well thanks for all your help guys..
Turns out turbo water return is supposted to be connected at the tee off of the thermostat housing and not the tee in the back of the block..
No more gurgling heater hoses. Took about 500 pages of research online, to find one with my same problem.
Heres the link for the other jerkoffs out there with the same problem.
Good day mate.
http://forums.nicoclub.com/rb25det-pull-write-ups-abound-for-noobs-and-others-t194781.html
  • Like 1
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
