Nope. I have the 350z seats and didnt need one.
How?
Did the plugs match up?
I had to hard wire mine due to the differences in the plugs, even if they did plug together some lines were definitely different (two power wires on the seat plug, one on the car plug).
I have heard that M35s have two different types of seat plugs though.
Fuga seats look pretty good. I'm still not sure about going full leather again as found I was slipping around everywhere when I had them in my Legacy.
No idea how anyone lives with the stock fabric seats though...they are awful! Can't wait to replace them!!
I dont find this with the 350z leather seats as they hug body when in them. Not flat faced like most
  • Like 1
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
