Hey guys,
Selling my Original rays TE37s 18x9.5 +12 with bridgstone S001 tyres.
These wheels have no gutter rash and are in amazing condition. They were originally on my evo, which i have sold without the wheels in order to make the sale cheaper for the buyer. The wheels have stretched tyres 235 45 18 in order to make them fit. The wheels are more catered towards GTR's or flared evos running 265s. They do fit GTT/GTST however you will definitely need to roll the guards.
FYI: The wheels were really dirty when i took the pics, so it doesnt really do the wheels justice. Looks very nice on a skyline! Added a pic for reference
Pickup only - south east suburbs.
Price: $3000 ono with tyres
Edit: Forgot to add, the wheels used to have light gutter rash however these have been fully restored and the whole wheels resprayed. No damage, no buckles
  • Like 1
https://www.sau.com.au/forums/topic/466402-sold-18inch-genuine-rays-te37/
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
