[SYD] FS: HKS 2835 Pro S turbo, Apexi PowerFC, Z32 AFM, Greddy Profecb II boost controller, and more..
Hi everyone, i have some parts that will be coming off my car shortly, so ALL parts are currently still on the car for about a week... if you are interested PM me and we can work something out.
Item 1:
Genuine HKS 2835 pro S turbo .68 rear with dump
$1500
Item 2:
Apexi PowerFC with hand contoller to suit RB25DET Series 2 (might suit Series 1 not sure)
$1000
Item 3:
Greddy Profec b II Boost controller
$200
Item 4:
Coolingmist water methanol injection kit with tank and in cabin gauge
$200
item 5:
RB25DET Standard exhaust manifold
$80
Item 6:
Z32 Air flow meter with plug
$150
I will have more to come so i will keep updating this post.
All parts are located in Sydney, Liverpool. Pick up preferred. Thanks.
Just wondering if you'd be keen on some postage to Canada? Looking at that manifold. Thanks!
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
