R33 engine build etc.
Hey guys, so I am really new to this group but have been reading for awhile now. So it has come to a time in my life where I need to fix my car, upgrade the engine and make dream become reality (money permitting xD). So, if anyone actually reads this (i'll be suprised) I hope you enjoy the small journey that me and my car are going through. Lets start posting!
Ok, so I've got some photos from a few moons ago. So I will do a sort of chronological order of whats happened and what is going on.
First was coilovers and rear toe arms for me, funny story this one! So I was having major problems with my hicas (surprised I know!) when I bought the car (twas a lemon!). So I ended up instead of putting a lock back on the rack, I unbolted everything, and installed adjustable toe arms. So in the process of removing the rack ends from the rear stub axles, I employed the technique of smashing the lower part of the stub axle with a hammer to break loose the rack ends. Well, this is where it becomes interesting. I had noticed while driving the suspension was rather 'bouncy' and I now know why. While hammering the right side, I noticed that the bottom of the left rear shock was dripping, with water. Yes, I still don't know how but there was a crack in the bottom of the shock canister, and water was coming out. SO, I carried on and started smacking the left side. A short while later I inspected the right side and it too had started leaking, but it was oil and from the top of the shock. Talk about hard luck!!! To top it off, I had to end up using a machine press to get the bushes out of the stub axles to make room for the new style of the toe arms. Anyways, I got the toe arms in. I got the coilovers in and happy, days rock solid.
14212634_10208921024235154_575458154728708672_n.jpg14238287_10208921024355157_3996752898717628744_n.jpg
Second was my exhaust. Now everyone loves a mean sounding rb25, and what better way to do it than with STAINLESS!!! Its a mild steel 3" dump, 3.5" pipe, 100 cell cat, more 3.5" and a 6" tip cannon.  Sorry, no story here. Unless you want a video of me crying as I paid the nice exhaust shop people...
14291715_10208920897311981_488161662704705903_n.jpg14238145_10208920896951972_8955192458670587858_n.jpg14333145_10208920895831944_5922674137313950142_n.jpg14322499_10208920896231954_6665488252765989022_n.jpg
Third was more suspension, but in the front this time. Now, when I bought this car it was cheap. And for reason! Stupid thing was in an accident many moons ago and written off, but someone cared enough to put it back on the road and do the repairs. But little ol' me, has been left with mess of warped/twisted/bent suspension and chassis components. So, I bought some adjustable lower control arms with castor adjustment, and also a slightly less bent subframe. Alas, I was young, inexperienced with the Japanese monster. And there was much fun to be had with trying to match up the subframe and the lovely bolts that are for some reason, on springs in the chassis rails. A little bit of modifying, swearing and lots of alcohol later... Finally managed to pry in the subframe (with elongated holes, dodgy much). And once again, because of the twist in the chassis, the lower control arms were just as fun trying to fit them in...
14233075_10208920897751992_1346727676180838200_n.jpg14333194_10208920898112001_1509850133234051791_n.jpg
Fourth. So this next one isn't really an upgrade, but it kinda is, because I don't have photos of it sadly. BUT! It is a good story and rather interesting. So, I was washing my car and doing all that stuff, and went to move it into the shade to dry it. Dried it off all nice and pretty like, and then went to move it again but it wouldn't start. The battery wasn't dead, but there was no turning over of the motor. So I started to think maybe, the starter motor had stopped in a dead spot (im sorry I don't know the term for it). So started whacking the starter and tried at the same time, and still nothing. Tried to roll start it and every time I let the clutch out, the rear wheels would skid and not roll... So I thought maybe the starter was stuck/seized. So got it towed home (as I was at work). And then started to pull the starter out. Now, I ran out of time day 1 to do so and then started freaking out that the motor had seized (completely illogical I know). Pulled the starter out, and found this little piece of metal fell out. Bench tested the starter, all ok. Turned the motor over, all ok. So everything was good? Put it all back together and started the car, first time! So what stopped the car? A small piece of metal. I believe it was stuck between the starter and the flywheel (but who knows exactly). I later found out when I replaced my clutch (no photos sorry), that the washer for my pivot ball was broken. Lone behold, the same colour, same thickness, same curvature, it was the missing piece of my washer.
10891776_10204511247753498_6482449174164637190_n.jpg10676287_10203925022698238_3388805586236337472_n.jpg
Fifth was a small bit of handy work on my wiring. My clock in the car never worked. Well I lie, it worked but it never had any memory power. All it did was to turn on with the car, start from 0.00 and basically start timing my drive. So I wanted time, and I knew how to do it. Pulled the trims off need to get to my clock, bench tested it to see what pins did what and how to wire this thing up properly to keep time and work as its meant to. As these things tend to have a habit of one thing leading to another, in the process I pulled my head unit out. And found a bird nest of wiring, which was great! Especially when you find out there is a loom plugged into a loom, twisted and taped into my head unit. FML. Sorted out the clock, wired that in, happy days. I then sorted out the wiring for my head unit, purely based on my personal hatred for people who twist and tape! Solder it in, crimp connectors onto it people!!! NOT HARD!!!
Sixth is what I am currently doing now. This is the start of some minorish engine work. So, end game at the moment is to get the car back on the road with around 400hp. But to do that, one must spend ones hard earned cash on things such as engine parts. So some things are off and out to be worked on and replaced. As you will see in the very last photos, the front bar is off and headlights out, intake piping, airbox, charcoal canister, turbo and exhaust manifold. Plans are at this stage, turbo, dump to suit, waste gate if needed, injectors, fuel pump(maybe an external), surge tank(maybe?), intake manifold, coilpacks, cam gears, cam shafts and computer. Oh did I mention I got a dirty 30 block xD. I don't know if Im going to use it yet, still tossing up the idea.
14316877_10208920895231929_1026411827428792790_n.jpg14232626_10208920906552212_9122320027735021939_n.jpg14233049_10208920906792218_2934841633412955056_n.jpg
  • Like 3
https://www.sau.com.au/forums/topic/466760-r33-engine-build-etc/
just read your post I'm very new to this page and the whole owning a skyline thing myself haha.
impressive work i must say, not many people would have bothered with such a heap so hats off to you for returning it to its glory days :D haha.
i myself bought a bit of a lemmon to start with fortunately I'm working out the kinks. before i go any further ill admit whilst i do know a bit about cars,
i am a builder that is not physically do the work myself apart from fitting my own tyres. everything else i am just entrusting other people with actual expertise in the fields haha
much to everyones dislike as my friend said to me( I'm not building my car I'm paying people to do it for me haha)
if you'd like to hear more about my R33 adventure feel free to hit me up and share ideas as my build has only just begun.
  • Like 1
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
