Hi guys time has come to sell the 8. I've had it for 2.5 years bought it when it had 72k kms on it and performed ALL the mods on it. The oldest of the mods are 1 year old. Turbo, flex setup, cams, cooler not even 10k kms on it. The car is in beautiful condition, any inspection welcome. I drive it once every 2 weeks, sits under a car cover when not being driven. No major accident history. 25k neg, contact number 0402260288 or pm me, thanks!!
SUSPENSION
- White line rear swaybar and adjustable end links.
- New H&R street coil-overs.
- New genuine shock tops.
FUEL SYSTEM
- 400lph e85 fuel pump.
- ID 1000 fuel injectors.
DRIVETRAIN
- Clean and inspected gearbox, new bearings seals etc.
- OS giken Str twin plate clutch.
- Braided clutch line.
- Shifter base and linkage solid bushes.
- New solid shifter linkage bushes & shifter base bushes.
EXTERIOR
- New genuine Mitsubishi 8mr headlights.
- 8mr taillights depo.
- Rocker cover respray with new gaskets and stainless bolts.
- New LED Parker globes.
- Seibon full carbon rear spoiler costs over 1k
- Genuine Evo 9 rear bar.
- New wiper arms & front deck garnish.
- New ssr sp3 18 inch wheels with new kumho ku31 tyres.
ENGINE
- GSC S2 cams with beehive valve springs and Ti retainers.
- GTP712 turbo.
- ARP upgraded head studs.
- Timing belt, water pump, cam & crank seals, pulleys replaced.
- New coilpack cover.
- Pierburg boost control solenoid.
- Coil on plug kit.
- Invidia dump pipe.
- Invidia front pipe.
- High flow cat & test pipe. Exhaust modified for flow.
- Ceramic coated turbine housing and exhaust manifold.
- Plazmaman intercooler.
- Meek hotside intercooler pipe.
- Ethanol sensor and flex tune.
- Turbosmart kompact BOV
BRAKES
- Braided brake lines.
Power 286awkw @ 25 psi on e85 ~ 245awkw on 98
Bad points : Calipers need painting and front left wheel has some gutter rash : ( cost around $200 to fix.
Edited by ludi_konj
https://www.sau.com.au/forums/topic/466950-vic-mitsubishi-evo-8-25k-116xxxkms/
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
