EOI Trade - 290kw JZS147 aristo 2JZ for GTR 32/33
Wanting to trade my single turbo JZS147 aristo for a lightly modified R32/R33 gtr in Sydney. Or even sell outright if someone is interested.
Not massively fussed on colour, just a clean body with no rust & light modifications is mainly what I'm after, only wanting a weekend street car for now, as the aristo has been for a few years.
Reason for trade is i have no need for the big 4 door, i miss driving manual as my daily is also an auto, & all my spare bits & pieces are for an RB26, not so good for a 2jz.
Quick specs list:
* 1995 S2 in black with leather interior & factory sunroof, factory LSD, cruise control
* Rego valid until September 2017
* shift-kitted auto gearbox with trans cooler & factory converter
* 2JZ with single Garrett GT3582 turbo making 286kw at the wheels on 18psi
* Apexi Super AFC piggyback on standard ECU
Turbosmart eboost street boost controller (set to 15psi low & 18psi high boost)
19" work meisters
Veilside twin 3" exhaust
* adjustable fuel pressure reg with gauge in engine bay
* I'm sure there's a whole lot more I've forgotten here
Plenty of work done, this is a quick car even for its weight & size. Traction control is there for a reason. I've had this car for the past 3 years now, had a lot of maintenance & servicing work carried out to bring the car back up to a reliable level:
* radiator replaced approx 12 months ago
* lots of seals replaced as it was leaking oil in a few places (no longer), these include front & rear mains
* turbosmart 40mm external wastegate installed & plumbed back into exhaust - approx 12 months old
* turbosmart bov fully plumbed back - approx 12 months old
* Apexi Super AFC & Turbosmart eboost installed as part of upgrade works roughly 12 months ago
Car value is being listed at $13K neg, I have roughly 10K in receipts alone for work carried out in the past 2 years. I can add cash on top for a tidy GTR up to a certain point, or I also have a road bike which I can throw in to increase the value on my side.
Please PM me on here, or msg 0407 896 339 for further info, questions or offers.
Cheers, Chris
also would be interested in RS260 stagea, or possibly even GTR with blown engine
throw me some offers, worst i can say is id rather keep this beast
BUMP
possibly also keen on an RB25/26 powered cefiro / laurel or R32 GTS-T, maybe even an r33 or r34 for a swap closer to same value
throw me some offers & see what catches my attention
  • 1 month later...
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
