So i got a similar issue with my gts-4
When i try and turn into a car park or a sharp corner the whole front and rear lock up and you can hear the tyres skipping.
Have bleed the system - no change.
removed rear diff and checked diff ratio,  4.363:1
removed front diff cover checked diff ratio 4.363:1
front diff behaves normal when spinning wheels or the input
remove shaft from transfer case to diff and issue goes away.
Is there any other things you can check?  before i remove the gearbox and change the transfer case.
cheers
  • 5 weeks later...
Still haven't bled the system, but a new symptom just occur.
Took my car out for 20 minutes around neighborhood, kept under 4k rpm and under 5 psi, only a short cruise.  Drove back into garage and turned ignition off, then I heard a fairly loud electric hum in the trunk area that kept on for another 5 seconds, after engine already off.
Could that be the electric pump or solenoid for transfer case?  It definitely didn't sound like fuel pump.
  • 2 months later...
Finally after three separate shops had looked at the vibration and grinding issue, the conclusion is that my car has a fairly aggressive front LSD.  So rather than vibration or grinding, it's actually bad LSD chatter amplified by incorrect differential fluid not allowing any slip.
The recommendation is to add limited slip friction modifier, which should be a simple and economical remedy.  So I'm going to research a little more on friction modifier and see if that really helps.
  • 2 months later...
A quick update.  The vibration and grinding issue has been fixed, and the problem was indeed with the front LSD.
Initially I had the front LSD drained and filled with Redline Heavy Shockproof, and it just made the issue worse.  So I contact Redline (which by the way has excellent customer service,) and they recommend adding some of their own brand of LSD friction modifier.  To my surprise it works like magic, and I very much enjoy driving my car again.
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
