So i got a similar issue with my gts-4
When i try and turn into a car park or a sharp corner the whole front and rear lock up and you can hear the tyres skipping.
Have bleed the system - no change.
removed rear diff and checked diff ratio,  4.363:1
removed front diff cover checked diff ratio 4.363:1
front diff behaves normal when spinning wheels or the input
remove shaft from transfer case to diff and issue goes away.
Is there any other things you can check?  before i remove the gearbox and change the transfer case.
cheers
  • 5 weeks later...
Still haven't bled the system, but a new symptom just occur.
Took my car out for 20 minutes around neighborhood, kept under 4k rpm and under 5 psi, only a short cruise.  Drove back into garage and turned ignition off, then I heard a fairly loud electric hum in the trunk area that kept on for another 5 seconds, after engine already off.
Could that be the electric pump or solenoid for transfer case?  It definitely didn't sound like fuel pump.
  • 2 months later...
Finally after three separate shops had looked at the vibration and grinding issue, the conclusion is that my car has a fairly aggressive front LSD.  So rather than vibration or grinding, it's actually bad LSD chatter amplified by incorrect differential fluid not allowing any slip.
The recommendation is to add limited slip friction modifier, which should be a simple and economical remedy.  So I'm going to research a little more on friction modifier and see if that really helps.
  • 2 months later...
A quick update.  The vibration and grinding issue has been fixed, and the problem was indeed with the front LSD.
Initially I had the front LSD drained and filled with Redline Heavy Shockproof, and it just made the issue worse.  So I contact Redline (which by the way has excellent customer service,) and they recommend adding some of their own brand of LSD friction modifier.  To my surprise it works like magic, and I very much enjoy driving my car again.
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
