95 180sx - Sr20det, manual - Clean
Hi all,
Regretful sale but i need to get rid of all my projects.
I have for sale a 1995 Nissan 180sx sr20det manual, 180km (genuine), the car has been owned by the one mature owner for the last 12 years since it has come into the country!
Factory airbag and hicas and SUNROOF! no leaks and no annoying wind noise on the highway!
The car is stock standard except for a quiet catback exhaust, alloy radiator, lowering springs and decent sound system from 2005 lol!
Motor is healthy and the car drives really well, interior is clean and dash is untracked but does have a few marks on the right corner (comes with a dash mat).
Getting harder to find these cars unmolested.
The car has a few blemishes expected of a car this age but nothing major and no accident history.
Has registration until 03/17
no rwc
located S.E vic,
$12,500 ONO
SMS preferred - 0432777767
Edited by maq23
https://www.sau.com.au/forums/topic/467551-95-180sx-sr20det-manual-clean/
  • 3 months later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
