You can replace it with one of these, goes from master to slave cylinder http://www.ebay.com.au/itm/HEL-Braided-CLUTCH-Line-kit-NISSAN-Skyline-R32-GTS-T-GTST-Full-Length-/271611272122?hash=item3f3d4b1bba:g:5OwAAOSwnDZUG52L Pm Dose Pipe Sutututu (johnny), he can probably do a better price. The other options are brand new oem from Nissan, wil most likely need to be ordered or second hand oem from a wrecker like skyline spares in Sydney or Osaka imports in Melbourne. Where are you located by the way? As far as bleeding at every joint, it means where the hose screws into the master cylinder, you need to loosen it 1/2 to 1 turn and bleed the master cylinder from there, tighten the fitting fully and move on to the next join and repeat and finally bleed at the nipple. Does that make sense to you? You may be able to get away with just bleeding from the nipple you may not.
Yeah I will definitely get that one in the future problem is I dont have time to wait for delivery as I already bought an unregistered vehicle permit so I only have a limited time to get a RWC. Im located south east melbourne.
Image result for r32 gtst clutch master cylinder
So I bleed the master from the nipple on the right or the fitting under the reservoir?
3 minutes ago, admS15 said:
Bleed both, cant hurt. Try Osaka imports in knox for a used clutch line or find a local hel distributor.
Yeah im gonna take it to a local clutch place and hope they can give me a new line at least for a temporary fix then imma get the RWC and switch everything to braided
19 hours ago, Ed.williams5 said:
Your best bet is go and have stainless line made up.long enough to go from clunch master down to slave then just have to worry about one.
This? : http://www.ebay.com.au/itm/271611272122?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Will this mean I can completely bypass the dampener as well and remove all the metal lines?
Yes
31 minutes ago, KiwiRS4T said:
Yes
Thank god. I the little screw thing that goes in the dampener is leaking now and the nut is completely rounded, was seriously about to just give up
57 minutes ago, KiwiRS4T said:
No you can rip it out
Yeah thanks guys in this thread, i bled the clutch and the brakes as well and now everything running even better than before so THANKS :)
  • Like 1
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
