R33 GTR 36k
Hey all, im trying to sell my R33 GTR
Full rebuild
87mm cp Pistons
Manly rods
Acl mains
tomie cams 10.8m lift
Tomie cam gears
Tomie head studs
Tomie valve springs
Port and polish
New valves and sleeves
1000cc injectors
G reedy fuel rail
Speed flow fittings and braided fuel lines
Bosch 040 fuel pump
Tomie hi flow oil pump
ATI Dampner
Apexi power fc
6 boost ceramic coated turbo manifold
Gt4088r Garrett turbo
50mm external waste gate
Larger 3inch intercooler
Hks blow of valve
3.5inch exhaust stainless nissmo
E85
Reco gear box with exceedy twin plate clutch
19inch wheels
Fresh respray
Just been dynoed on 17-18psi for run in tune just under 500 hp
thanks
https://www.sau.com.au/forums/topic/468540-r33-gtr-36k/
put a proper ad up, linking to elsewhere is lazy,
also your apparently asking SAU for $2k more than whats on the add? where is the love man.... where is the love?
https://www.sau.com.au/forums/topic/468540-r33-gtr-36k/#findComment-7804379
  • 1 month later...
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
