For a complete novice it would take 4-5 hours if you take your time and document everything.  Get 20 zip lock bags and put all of the nuts and bolts in labelled bags.  Take heaps of photos.  It all helps when you go to re-assemble even if just for routing of hoses/wires/etc.
While you're at it (if not done prior) replace EVERY cooling system hose under the inlet manifold.  Use genuine if you can afford it.  Also replace all vaccum hoses especially the ones that run around the back of the head for the waste gate actuators.  after 20+ years they all go hard and can crack.  Being where they are located you don't find out till it's too late!
https://www.sau.com.au/forums/topic/468591-intro/page/2/#findComment-7804586
Oh, man, if you want a list of all the things you should replace when you have taken that much of the engine apart, it includes (but is certainly not limited to!)
  • All gaskets.  Obviously enough, but people do sometimes expect to be able to reuse turbo and dump gaskets and so on, and if they are older than a very short time, it's better to replace.
  • The heater hoses that connect the engine to the firewall.  They are well old now too.  They probably fall under the category mentioned by Shoota above.
  • The timing belt, obviously enough, unless you know that it is recently replaced.
  • The water pump.  Thermostat.  Radiator hoses if they don't feel fresh.
  • Head studs.  Prime time to put ARP ones in.
https://www.sau.com.au/forums/topic/468591-intro/page/2/#findComment-7804588
On 13/01/2017 at 5:32 PM, 89CAL said:
Its been a while but arent there some plugs up around that area? I assumed they were for coolant but could be wrong. Worth pulling the whole coil pack assembly off i would think if you havent already done so.
Also, its easier to undo the 5 bolts that hold the coil pack brackets in place to do plugs than to pull each individual coil pack off. If it helps :)
That was the plug I was talking about. I think there are a few along the top of the head. Wouldnt hurt to pull all the coilpacks out and check. They may be for oil though. I'm not 100% sure
Edited by 89CAL
Extra Info
https://www.sau.com.au/forums/topic/468591-intro/page/2/#findComment-7804775
Update: I did a compression test and a block test to see if any exhaust was in the coolant system.
Block test: Negative
Compression Results: each cylinder was done 3 times and the engine was warm. I did not have the throttle wide open during the test.
1. 160
2. 160
3. 160
4. 160
5. 160
6. 152
https://www.sau.com.au/forums/topic/468591-intro/page/2/#findComment-7806654
  • 4 weeks later...
So here's an update: I'm saving up money to purchase a new head from TOMEI so in the meanwhile I used JB Weld to fill the hairline crack in my head. It has been 3 weeks and not a drop of coolant has leaked from the where the hairline crack was. I was very iffy about using JB Weld on my cylinder head but to-date it has worked wonderfully.
https://www.sau.com.au/forums/topic/468591-intro/page/2/#findComment-7811788
    • Was the failed sensor by any chance this one? Did it just fail or start pissing on itself? I ordered one too, for fuel pressure monitoring, and now I am hesitant to put it in, hehe. Where did you find a brand one?
    • You'd be insane, when a brand new 8HP is ~$4k, and all the work to put a 6 in would cost the same as an 8 and the 8 is a completely established swap. If you think that getting a cheap Falcon box is going to make it a cost effective exercise, then you're not accounting for the extra $10-15k that the task will consume.
    • any further information on this? also interested in putting a zf6 in behind a rb30!
    • They're all horrible. X-Trails have had a nasty sounding 4cyl since forever, no matter what engine family it came from. The CVTs only made that worse. Then the whole Renault thing only made every Nissan that was contaminated by them even worse again. The only fun I've had in a X-Trail was having it blown sideways across a frozen Minnesota highway at 90 mph trying to make it to the airport to get out of the frozen hellhole of Hoth. Nearly died. Was great fun.
    • Alrighty, I'll have to grab a couple pics and type out something soon in another post. I haven't driven a modern X no, this would be the first one really. Yeah the rental boxes are always cheap as chips right? So I'd doubt that anyone was handing out GTs to go and abuse. But I s'pose I could be wrong for sure. New cars these days though? Pretty unimpressed with what I see now; 20 years and all that, like you said. It just kind of worked out to have these two cars now. I'm pretty pleased with that, don't need much else. I'm sure you lads are right about the temps and for sure, you wouldn't have much time to drive 'em down there if you all were like me. I do hate sweating all over the seats though😆
