This car is in imaculate condition, genuine buyers only.
SPECS:
N1 oil pump
HKS step 1 camshaft
DENSO 700 cc injectors
Alexi power fc
Trust drag intercooler and piping
PWR oil cooler
ORC twin plate clutch
2860-5 Turbos
TOMEI timing belt
Koyo twin core radiator
Trust turbo back exhaust
ARC catchcan
Spit fire coil packs
19 inch deep dish work meister rims
HKS height and damper adjustable suspension
Custome roll cage (no holes)
Top secret carbon fibre bonnet
Nismo
63000km
Asking price :$ 85k
clusterScreenshot_2017-01-27-11-01-28.pngScreenshot_2017-01-27-11-01-08.pngScreenshot_2017-01-27-11-01-22.pngScreenshot_2017-01-27-11-01-14.png20170127_105338.jpgScreenshot_2017-01-27-11-01-18.pngScreenshot_2017-01-27-11-01-20.png
https://www.sau.com.au/forums/topic/468820-99-nissan-skyline-r34-gtr-vspec-92/
Owned by mature driver
Car has never abused nor taken to the track
Currently pushing around 500 rwhp, potential for much more.
*Corrections in original post:
  • Apexi Power FC (not Alexi)
  • Nizmo Cluster
Edited by Vader681
corrections in original post
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
