Hi guys,
So time has come to cleanout some of the spare parts I have laying around.
All items are located in Gladstone Queensland. Can post at buyers expense.
PM preferred.
For sale is as below:
1/ Std GT-R turbos. Very minimal to bo shaft play. Selling due to upgrade with new engine. Only run stock boost. $450 ono
2/ Std GT-R injectors. Good working order. Selling due to upgrade with new engine. $200 ono
3/ Std R33 GT-R ecu. Good condition. Selling due to upgrade with new engine. $100 ono
4/ GT-R brake air ducts. Good condition. Selling because they dont fit with new lip. $100 ono
https://www.sau.com.au/forums/topic/468840-garage-cleanout-r33-gt-r/
  • 3 weeks later...
  • 1 month later...
  • 2 months later...
  • 2 months later...
  • 3 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
