See pics.
Do most guys weld some more steel here for a good seal or consensus is it isn't needed?
I have heard both but can't find any comments on sau about it?
I have a good fabricator that I reckon can do it then obviously just get the block decked.
Thoughts?
ImageUploadedBySAU Community1486786531.550216.jpgImageUploadedBySAU Community1486786547.403397.jpgImageUploadedBySAU Community1486786561.056198.jpg
6 hours ago, czy18e said:
Thanks angry RB, do you know what method he used? Welding to cast iron can be tricky.
I had the head welded to suit RB30 gasket, also VCT done, easy work for a fabricator
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
