Looking for a tommy Kaira front grill for R32 GTR
Hey guys so on the hunt for a tommy kaira front grill for my R32 I've been digging online for one and can't find one so if anyone has any kinda direction please let me know.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
