Trust Titanium Cat Back Exhaust R32 GT-R
Selling a Trust Titanium cat back exhaust to suit an R32 GT-R (maybe GTS-t?)
Light weight and high quality exhaust, in excellent used condition, no dents, obvious scratches, etc.
Does have a few water marks so could do with a polish of some sort.
See attached photos. Appears to be 3" (76.5mm) internal diameter, 115mm tip, comes with original documents & Jasma certificate.
Located in Brisbane, looking for $1400 ONO, can ship at buyers cost.
Edited by ph1
added size info
  • Like 1
Weight is 8.6kg, 4.8kg for mid-section and 3.8kg for rear section.
Unsure how much use it has had, came off a car I just imported with under 25,000 klms, but not sure when it was fitted.
Can freight to eastern states for $50, will need to check costs to other areas.
Edited by ph1
  • 3 weeks later...
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
