18in Works XT7 rims - Powdercoated Satin Black
Hi Guys,
I have had these Works XT7 rims for nearly 10 years as they came with the car when originally purchased.
The rims are 18x8.5 and 18x9.5 and sit perfectly on an R34GTT with no spacers etc... Ill have to check the exact offset but i believe it was around the +30 mark from memory.
The rims have been professionally sandblasted and powdercoated in a Satin Black to match my engine bay and car theme at the time.
10631153_819500188119906_4367579277799674675_o.thumb.jpg.1461017791755aeebc7f1a9d5812663a.jpg
1272468_819491551454103_223502258470674618_o.thumb.jpg.38ceba23b315128011df6c733ac9c3a4.jpg11194550_819512154785376_5028235203771741646_o.thumb.jpg.132b4e149a40036b1c34f6b291afedfd.jpg
The rims had some rash repaired back in 2012ish (Check my build thread for pics and exact dates as its all in there)... This was when the powdercoating was applied.
Genuine reason for sale, i held onto these for a few years after upgrading the car as i intended on getting another GTT for a daily but plans have changed and i would rather upgrade the race car instead. I currently run 18x10.5 rims all round due to the new widebody setup so these are no longer of any use for my GTT.
The rims are off the car with no tyres fitted, they have been polished and stored in the house for the last few years so they are clean! I have an old set of 275 tyres for the rear i can chuck in with the sale, they were fitted to the car at some stage. I also have the original blue alloy Works wheel nuts, lock nuts and locking key, however they were removed from the car as one or two of the nuts had a damaged thread...
I can get decent pricing on tyres through a good mate, if you are interested in tyres please let me know when you enquire and ill pass on the information. On the front rims i have previously run 235/40/18 and also a 255/35/18. On the rear i have run 265/35/18 and also a 275/30/18 (The 275/30 can be thrown in with the sale at no cost as they are just sitting in a rack).
The rims are located in the Newcastle area. Not keen on shipping them anywhere just yet, would prefer the buyer inspects them prior to purchasing. If shipping must be done it will be at the buyers expense and although they will be packed the best they can be i will not be responsible for any damage caused in transit.
Asking price is $1000 and is not negotiable.
Best method of contact is via PM as it will notify me on my phone and ill get back to you ASAP.
Cheers
Mat
  • 3 weeks later...
Bump, Still available... Now with added tyre options -
$1200 with brand new Zestino 240 treadwear street tyres supplied
$1500 with brand new Zestino 140 treadwear Semi Slick style street/ track tyres supplied.
These Zestino tyres are brand new and are amazing value for money. These are currently available from K Racing if you are interested in purchasing separately.
  • 5 months later...
Price dropped to $800.00 firm - NO OFFERS
With throw in the old 275/30/18 tyres for the rear at no cost as they are in my way.
No tyre offer available with this new pricing as it is cheap for a quick sale! Need to fund a new engine!
  • 5 weeks later...
On 18/12/2017 at 2:43 PM, 34GeeTeeTee said:
Still available.
:cool:
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
