Hey Guys
I will be offloading my 1996 RSFOUR in the next month or so.
Silver, twin sunroof/airbags, ABS, etc, 98,000 kms original. Exhaust.
Immaculate condition with leather.
Alarm/immobiliser.
Complied by skylineimports.
0414561121.
Low twenties required.
M
https://www.sau.com.au/forums/topic/47049-1996-stagea-rsfour-4-sale/
hey mate. I have been in the market for a stagea for a few weeks. I have the money ready and a set budget allocated. I am ready to buy one right now, however i am dealt a bit of a problem. I can import one and get it complied and landed for a cost of about 17 for a car similar to yours. The only problem with this is that i will have to wait a few months to get it. I am wondering what the best price for yours is in cash.. i can have it ready for you as soon as it lands for an easy transition... Please keep in mind, the sort of car that can be had for 17 is similar spec to yours, with less then half the kilometres... thanks for your time
alex
