i will keep a look out for further updates i am interested in them it sounds like a worthwhile alternative to getting 550cc injectors.I am not after more than 250rwkw and im guessing with an increase in rail pressure they can be pushed closer to 500cc.
Are they a straight swap injector?
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-952620
coming from the sr community, i can tell you there are a quite few people pushing there s15 turbos and injectors to around 200-210rwkw with some extra fuel rail pressure
and there pretty maxed out at around 190rwkw with stock fuel rail pressure..
so if you have 6 of then i would imagine something like 200/4 x6= 300rwkw would be possible with extra fuel rail pressure
there is someone on silviansw.com selling a set of 4 for $300 for anyone interested too :D
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-953643
I am currently converting my rb30 to turbo power and ive read that the vl injectors run out of steam pretty early in the piece. I have also heard that R33 GTR 444cc injectors may well fit straight in. If anybody knows it would be a big help. May as well buy the GTR injectors instead of the Holden variety if they fit.
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-953655
Simple numbers guys, 480 cc's in a 6 cylinder engine = ~480 bhp.
So 480 bhp / 1.34 = 358 kw
Less say ~65 kw for drivetrain losses = 293 rwkw.
That's at standard fuel pressure, whatever that is for an S15. Knowing Nissan, probably ~38 psi above boost.
Hope that helps :)
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-954758
GTR's are top feed low impendence.
You'd need the resistor pack also and probably a custom/GTR fuel rail (?)
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-954777
Check out http://www.calaisturbo.com.au/index.php
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-954840
I believe that late ( '96 and later) model 300zx VG30 uses injectors that will fit a RB25.
no responcability accepted for accuracy of information in the previous sentance so don't come running to me when your pistons are a melted pool of slag in your sump... :-)
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-955846
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
