Top notch NITTO RB 26/30 gear for sale and more.
Up for sale is a complete short motor assembly.
Nitto/je forged billet pistons with upgraded pins and rings
Nitto i beam rods with upgraded arp 2000 rod bolts
Nitto high vol oil pump
Nitto crank collar
Nitto rb head drain
Nitto DBS o ringed metal head gasket
Cost me 5 and a bit grand. Letting them go for $4600 FIRM
Also have a complete stock untouched rb26 head with all covers. Throttle bodies and inlet plenum. Buy the head and take a free RB30 stock short motor with it! $2000 FIRM
Rb30 s2 complete short motor (stock untouched)
Will not seperate any of the nitto parts unless buyers have mates who will take the rest. Not negotiable on any of it either.
Phill - 0421 986 981 - Prefer Text over Private Message.
Located Northern Suburbs Melbourne (Thomastown)
  • 3 weeks later...
On 2017-6-19 at 10:06 AM, duz10s said:
head with stock bottom end still available?
Sure is. Complete rb26 head with complete (stock) rb30 series 2 bottom end. Text me on 0421 986 981 for any further info.
  • 3 weeks later...
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
